Re: Searched_300 Util. belt change. (Rookie ?)
Posted by Rob J on November 13, 2002 at 11:25:00 from (66.89.165.66):
In Reply to: Searched_300 Util. belt change. (Rookie ?) posted by cole on November 13, 2002 at 09:59:14:
I'll add that even with the pulley split it could be a little trouble (I have a 384). If so then put the belt around the water pump pulley first, then start it on the right side (looking at the front of the tractor) of the crank pulley. Tap the starter (disconnect the coil so it won't start) to pop it on the pulley. Then tighten the split pulley. Tighten the pulley a bit then crank it over a few times to get the belt up higher on the pulley. You may have to do this a couple times. Then tighten everything up and check it again in a couple weeks as mentioned.
Good Luck,
Rob
Post A Followup
: Re: Re: Searched_300 Util. belt change. (Rookie ?)
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
