Re: Farmall H thermostat
Posted by dick on November 15, 2002 at 08:38:13 from (63.211.243.48):
In Reply to: Farmall H thermostat posted by John on November 14, 2002 at 18:22:59:
From your description, you should have the thermostat in correctly. The housing has an internal passage for the bypass flow which won't drain unless you orient the housing properly. The flow goes to the rectangular cutout you'll see in the housing gasket. If you can't get the housing to drain by tilting, the passage is plugged and you won't have any bypass flow. Trying to unplug it somehow is a good idea.
If it was me, I'd work on getting rid of all the scale and crud I could, but it's your tractor. Tractor was designed to operate with any coolant from water to alcohol to whatever, so use whatever suits your fancy. RTV certainly helps if you've got problem gasket surfaces.
Post A Followup
: Re: Re: Farmall H thermostat
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
