Farmall Tractors Discussion Board |
Re: Farmall A runs and then sputters to death in 20 minutes
Posted by Daniel on August 26, 1999 at 16:29:20 from (152.163.197.198):
In Reply to: Farmall A runs and then sputters to death in 20 minutes posted by Marty on August 26, 1999 at 06:44:29:
Unscrew the elbow that connects the fuel line to the carb. There is a screen on the end threaded into the carb. This needs to be cleaned every so often because it gets clogged from rust from the tank and fuel line. It caused the same problem on mine. Would run good 'till it got under load then it would starve for fuel. Just one more possibilty to check. Happy hunting. If you rebuild the carb, NAPA has a good kit if it is a Zenith Carb.
Post a Followup
