Re: Rear axle seal on an A
Posted by Jonathan Mirgon on November 18, 2002 at 15:52:00 from (205.208.128.32):
In Reply to: Rear axle seal on an A posted by Rich on November 17, 2002 at 12:16:52:
rich,
I just replaced mine on both sides, some may disagree with me but mine did not come apart easily, the lower shaft that your talking about will come out, but hard. On mine after I had the cap off and bolt out of the shaft I used a long flat punch. I put the punch inside the threaded hole and beat on it for several hours. With no luck I got the sledge hammer out, three wacks on the punch with the sledge knocked it out. I would not say that the bearings are pressed on, beacause they can be removed without a press, but they are indeed a tight fit. If you putting the seal in behind the brake drum to, good luck the brake drum on mine came off extremly hard too.
Good luck,
Jon Mirgon
Post A Followup
: Re: Re: Rear axle seal on an A
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
