Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Electronic Ignition/The Red
Posted by ltf in nc on August 27, 1999 at 09:08:24 from (206.228.213.53):
In Reply to: Re: Re: Re: Re: Electronic Ignition/The Red posted by werf on August 26, 1999 at 22:10:29:
It may make more sense than you realize. In todays electronic world the most common failure in automobile ignitions is the electronic pickup sensor at the distributor. The electronic ignitions on the market employ this type of device. When the conversion is made using the technique I referenced the points only carry the trigger voltage/current. My opinion remains that the points are more reliable than the electronics when used in this mode. The item most likely to fail in the point system with the minute electricity now is the rubbing block. With the heat that exist within the distributor which do you think will fail first, the mechanical points or the sensitive electronics in the sensors circuit?
Post a Followup
: Re: Re: Re: Re: Re: Re: Electronic Ignition/The Red
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
