Belt change
Posted by Andy Kopel on December 02, 2002 at 17:08:11 from (12.45.76.149):
OK, I know this is an easy one for all of you old timers, but it will give you a good chuckle anyways.
I have a Farmall 350 and noticed that the v-belt that runs between the water pump/radiator fan sheave and a lower sheave is shot and needs to be replaced. I have two questions pertaining to this issue:
1) What does this lower sheave drive? I believe the hydraulic system is driven off of the timing chain and for the life of me can not figure out what this lower sheave is powering.
2) What is the easiest way to change the belt. I've been toying with removing the lower sheave, but it is tight in there and I'm hoping that there is an easier solution.
As always, any advise would be appreciated.
Thanks,
Andy
Post A Followup
: Re: Belt change
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
