The real cost of fixing up a Farmall H...
Posted by Steven@nd on December 06, 2002 at 14:34:05 from (12.23.184.133):
Several people have mentioned that I must be crazy to spend what I did to fix up my H. Well, I found the receipts for what I bought and totalled them up. If you only add up the necessary parts to get the engine together, that cost around $1500. Total cost of the tractor and mower to get it to useable condition is around $2800. I know I could have gotten by without some of the parts, but I believe in doing it once and doing it right. Here is the list: Part Cost Manifold $140.00 Spark Plug Wires $10.00 Headlight wire harness $10.25 Grommet for wiring box $2.00 Postage $6.00 Valve Job $45.00 Install Seats $48.00 Install Guides $28.00 Grind Crankshaft $89.00 Install and hone piston pin bushings $27.00 Install Cam bearings $15.75 Shop Materials $10.00 Freeze Plugs $1.43 Valve seat inserts (exhaust) $19.96 Valve seat inserts (intake) $9.64 Hi-Tack spray for head gasket $8.32 Cam Bearing set $32.36 Manifold studs $4.05 Fittings/line for oil pressure gauge $4.32 Case/IH Thermostat $18.32 Fan Belt $12.72 Generator Belt $9.17 Starter switch $13.81 Spark Plugs $10.00 Gear Lube $46.75 Hoses and Clamps $25.00 Liftall pump gasket and seal $16.69 Seal and bearing for PTO $24.67 Brake shaft seals $17.78 Transmission front seals $19.67 Water Cap $7.50 Throwout bearing $19.50 Pilot bearing $10.00 Wiring Harness $34.00 Oil pressure gauge $18.25 Temp gauge $46.75 Decal Set $27.00 Mag parts $22.25 Replacement engine block $275.00 Total in Tractor parts $1185.91 Mower Parts Sections, bolts, guards, hold downs $237.65 Hydraulic restrictor $2.25 Drive Chain $43.87 Sprockets/ repairs $75.00 Total mower parts $358.77 Cost of original Tractor w/mower $400.00 Cost of parts Tractor $150.00 Engine Kit $600.00 Mount Tires/new tubes $150.00 TOTAL ALL PARTS $2844.68
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
