Farmall Tractors Discussion Board
Re: Super C Oil Pressure
Posted by Ray on August 28, 1999 at 19:21:24 from (204.0.160.52):
In Reply to: Super C Oil Pressure posted by BigTool on August 28, 1999 at 12:44:52:
I just went through about the same thing with my A. After about the same amount of time my oil preasure would droup out to O psi. I'll tell the steps that I went through.
1.First I made sure my guage was good(I put a guage that I could see the psi.).
2.Next I pulled the oil pump off and it looked ok but I put it through a test. If you have some parts cleanne submurge only the oil pickup screan into the cleanner and put your finger over the outlet and spin the gear. As you spin the gear,look at the botton cover to see if the cleanner is comming from around it. What had happened to mine was the bottom cover was warped and the gasket was blown. Mine was warped so bad it wouldn't even pick up the cleanner,so I had to submurge the whole pump to prime it and after I did it just all sprayed out the sides. So what was happening was it would have oil preasute when the oil was cold,but when it got hot all the oil was going around the cover.
3.To fix it,all I did was get a sheet of sandpaper and a flat surface and reface it. If it's bad it might take awhile. After I got it refaced and reinstalled,now cold it has 40 psi and after it gets hot 18psi. So I'm happy with the outcome.
Hope this will help you,let me know if it does.
Post a Followup
: Re: Re: Super C Oil Pressure
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
