Re: Timing a 1950 Farmall H
Posted by Phil Auten (Tx) on December 13, 2002 at 18:52:21 from (64.157.112.233):
In Reply to: Timing a 1950 Farmall H posted by Ardie on December 13, 2002 at 16:51:20:
Ardie, References to first and second timing marks refer to which notch reaches the pointer first (or second) as the crank pulley turns. For a distributor (battery ignition): Connect the two clips to the battery, red to the + terminal. Connect the third lead to the #1 (front of the engine, closest to the radiator) spark plug wire. Locate the two notches (timing marks) on the front crankshaft pulley and the pointer on the engine just behind the pulley. They are on the same side as the spark plugs. When the engine is idling, timing should be at TDC, the second mark. As RPM is increased, the timing should advance toward the first notch. For a magneto: Loosen the hold down bolt for the mag and rotate the top of the mag towards the engine block. Set the timing marks to TDC (on the crank pulley, engine not running). Slowly turn the top of the mag away from the engine block, stopping when the impulse coupling makes a loud click. Tighten the hold down bolt on the mag. Check with a timing light as above, making sure the engine has enough RPM to not allow the impulse to click. TDC marks should still be aligned. While checking timing with a light, be careful not to come in contact with the fan blades! If the distributor or mag is not installed on the engine, you will need a manual, as there is a detailed set of instructions to follow. Hope this helps, Phil
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
