The clutch is held on to the outside of the flywheel by 6 bolts. There is a remote chance that you have to insert bolts into the clutch housing to hold the pressure plate together during removal. My SH does not have those, I think that is true of the later Rockford clutch that is on your tractor. Once you remove the clutch, the bolts for the flywheel are evident. As a caution, the flywheel is heavy. I usually put a block under mine in case I drop it. If you have the flywheel machined, be sure to have the machinest take the same amount off the step that the clutch bolts to as he does from the flywheel surface. I think the official spec from the flywheel surface to the step is 1.188 inches. The best buy you will find on a rebuilt clutch (pressure plate and disk) is from Steel Wheel Ranch, about $200 minus a $24 core charge plus shipping for my 460, about the same clutch. Includes pilot and release bearings. 785-548-7437.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
