Re: Super H water pump
Posted by IH on December 20, 2002 at 10:37:08 from (64.68.165.107):
In Reply to: Super H water pump posted by blarson on December 20, 2002 at 05:57:38:
third party image
You will see in the picture that there is a nut on the barbell shaped thing with the springs behind it. That is the impeller drive for the water pump. Loosen the nut and tap on it, it is a tapered pin. Then the barbell shaped thing should slide off, be careful not to loose the springs! Then take the 4 bolts out that hold the fan blade on.
What I've always done with rusted adjustable fan and generator pulleys is to soak them with PB Blaster or other good penetrant for a few days, loosen set screw, then use a punch and hammer and give a few good taps. They usually come loose then.
Post A Followup
: Re: Re: Super H water pump
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
