Re: F-20 - Bad spark and other problems
Posted by Bill Smith on December 22, 2002 at 18:13:15 from (63.147.130.88):
In Reply to: F-20 - Bad spark and other problems posted by John on December 21, 2002 at 20:33:16:
Plugs are cheap and easy to replace even if tractor doesn't need them. New ones might be the way to go. The other fellas have posted some good info here. The firing order should be 1342. I would just about bet that either the wires are hooked up wrong or the #1 wire on the mag is not timed with the #1 cylinder on engine. Might be a good time to go ahead and retime the engine. Take wires off, take valve cover off, and you should be able to stick a nail in one of those oiling caps on the front of mag to inactivate the impulse on mag (that is what makes the snapping sound when turning engine over). Now, slowly turn engine over watching the rocker arms and when number one is on compression, you need to stop engine at top dead center (removing spark plugs will make this alot easier). Also there is timing marks on the fly wheel through that whole on back left side of flywheel housing. These marks however are sometimes really hard to find and are also lined up at top dead center of exhaust stroke. The points need to open just slightly before top dead center of compression of #1 cylinder with spark advance in the run position (spark impulse must be inactive). If you can't find the timing marks you can stick a screw driver in the spark plug whole with one hand and with all plugs out you should be able to turn engine over by rotating fan with other hand and run the piston right to the top. Timing adjustments can be made where the shaft that drives the mag couples to the mag. When you know the timing is right, hook your wires up 1342. I never could find those stupid timing marks on my F-20 so always had to time the hard way. (note that even spark plugs and timing the engine may not get the old thing running). You could still have inadequate compression, faulty mag, or carberator not working right. It is just a process of elimination untill you pin point the problem but when you do and fix it the old girl will surely run. Good Luck and I hope you get it going.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
