Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Need help!
Posted by Pastor*Don on September 01, 1999 at 08:51:01 from (207.12.176.223):
In Reply to: Re: Re: Re: Re: Need help! posted by RAW in IA on August 31, 1999 at 19:40:38:
Okay, I was able to remove the plow from the hitch using a chain and the loader from another tractor. The cylinder looks as though it has traveled past its normal operation point (i.e. both are fully extended). I found this in the manua: "The retarder valve is to be set to the restricted flow position “R” when the depth adjusting cylinder is used on the fast hitch. This is necessary because the weight of an implement in transport or certain implements in operation would exert leverage against the depth adjusting linkage and tend to extend the cylinder. If the Hydra-Touch control lever is mover to raise the hitch point, the hydraulic fluid would escape from the piston rod side of the cylinder faster than the pump can supply fluid to the opposite side. This creates springy cylinder action or allows pistons to float." Does it seem right that I should bleed the system which would allow the cylinders to return to normal position? How would you recommend doing it now that the dangerous weight has been removed?
Post a Followup
: Re: Re: Re: Re: Re: Re: Need help!
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
