Re: Re: Re: Farmall H live hydraulics saga continues...
Posted by Bob M on January 10, 2003 at 11:40:26 from (165.170.128.68):
In Reply to: Re: Re: Farmall H live hydraulics saga continues... posted by Steven@nd on January 10, 2003 at 10:00:44:
Steven - Glad you found my comments helpful!! Here's a bit more: Although a universal joint is in principle a simple device, analysis of the output motion profile thru a U-joint is actually quite complex for anything other than the ideal straight line (no angle) condition. I can send you a calculation for a single joint operating at an angle if you wish. It'll fill an entire page, and guarantee will cause your eyes to glaze! However a rough rule of thumb says that for a two U-joint setup, IF the input and output shafts are parallel, AND IF the two joints are in phase, you can safely run a max of about 10 degrees of angle thru each joint at "reasonable speeds" (As a farm kid I regard "reasonable speed" to mean 540 RPM....) Change any of the above conditions you must reduce RPM and/or power transmitted to achieve reasonable performance and life. To your belt size question, by synchronous belt, I mean a flat, toothed belt like the timing belts used on many modern car engines - NOT a cogged B section V-Belt. There are several mfr's resources that will help you to figure the right belt/sprocket size. You might try Emerson Power Transmission (formerly Browning), Morse, Gates, etc - check your local power transmission supply house for catalogs and application guides. A quick look in my old Browning catalog says that a 1" wide type H (1/2" pitch) "Gearbelt", with 30 tooth drive and driven sprockets (about 5-1/2" outside diameter) is good for a bit less than 10 HP at 1,750 RPM - more than sufficient to run a live pump on an H. ...Bob M
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
