Farmall Tractors Discussion Board
Back EMF from coil..
Posted by HR on September 02, 1999 at 17:16:13 from (207.115.63.29):
All: I was busy today and missed most of the notes on were to put a resistor in a circuit earlier. I just want to add that when the coil is working there is a STRONG kick back caused by the spark arcing the plug and thus taking the secondary voltage down towards zero. This very rapid change across any coil secondary will cause a big change across the primary.. Could be a couple hundred volts kicked back across the primary and this may determine where the best place is toplace a resistor toprotect other parts like points.. This kick back from the plug firing will be only millseconds long but its enought to burn points.. So its a "hidden" problem that may not meet the eye at first glance.. There is a lot of energy being kicked around that coil just a small fractionof a second before & aftert the plug fires.. some old shops had a visual means to show this with a video display.. One could see the voltage spikes..which were very big in some units.... harvey
Post a Followup
: Re: Back EMF from coil..
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
