Re: TDC top dead center
Posted by Bill Smith on January 30, 2003 at 12:04:10 from (63.147.130.23):
In Reply to: TDC top dead center posted by STEVEN H on January 30, 2003 at 11:20:15:
TDC is when the cylinder is at top dead center of the compression stroke. Piston is also at the same position at the top of exhaust stroke. You will want to make sure the the cylinder you are working on is at TDC of compression stroke. You can insure that it is by (with valve cover removed) turn engine over by hand (using hand crank) slowly while watching rockerarms and valves. You might need someone to crank while the other watches. After intake valve gets closed all the way on the cylinder you are working on, give the hand crank 1/2 turn rotating engine. Then you can adjust the rocker arm clearance on both intake and exhaust valves on that cylinder. When you are done you can move to the next cylinder repeating the process all over again (rotating engine). Note that the valves on the head are from front to back (exhaust, intake, intake, exhaust, exhaust, intake, intake, exhaust). The first two valves are for cylinder 1, the next 2 for clylinder 2, and on down the line from front to back. When watching for the intake valve to close, make sure you are watching the correct valve. When closed the valve stem (has spring on it) is all the way up and the push rod is all the way down. And don't forget to rotate engine with hand crank 1/2 turn when intake valve is closed. You might check the manuel to see if there is a difference in clearance for intake and exhaust. Can't remeber if they are both the same clearance for the H. Manuel might also state whether the engine needs to be warm or not. If it states for it to be warm, then start tractor and let it run tell it gets to normal operating temperature before doing the clearance adjustments. If it doesn't state anything than it can probably be done on cold engine.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
