Farmall Tractors Discussion Board
F-12 crankshaft removal - How do I get the #@!% thing out??
Posted by Farmaller on September 06, 1999 at 17:39:34 from (63.67.89.157):
I have 2 F-12's. I have removed the engine from one altogether for the ease of removing the crankshaft and connecting rods/pistons. I have taken the front end completely apart and the crank is loose there. My problem is in the rear (sort of like a major pain in the rear!). I have removed all of the clutch assembly up to the flywheel. The major problem seems to be COMPLETE removal of the rear main bearing. I can't get it out because of this stupid splash plate between it and the flywheel. You know, the plate that the oil pan seals against in the rear. I removed the two bolts on the crankcase side, thinking this would free it. But apparently there are two more bolts on the flywheel side, that I can't get to! What is the easiest way to get the crankshaft out?!?!? (step-by-step please, I am a bit slow I guess!) My goal is to remove the crankshaft, cam shaft, rods and caps and install in the other F-12 which has a better block and pistons. Thanks for any help anyone can provide.
Mike in Arkansas
Post a Followup
: Re: F-12 crankshaft removal - How do I get the #@!% thing out??
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
