Farmall Tractors Discussion Board
Re: Farmall H [Knockin] Can I ?
Posted by RED Blooded on September 07, 1999 at 13:04:36 from (206.74.34.83):
In Reply to: Farmall H [Knockin] Can I ? posted by Matt Disher on September 07, 1999 at 10:44:58:
Maybe I can help.With the engine running see if you hear the knock,if you can push the clutch in and see if it stops.If it does its in the transmission.As far as the rod bearing goes,you can change it from the bottom,but I wouldnt recommend it.You could be chasing problems all day.Do like The Red said first and check your valve clearance first.Thought I had to rebuid a C one time and all it was was a valve out of wack real bad.As far as a flush,I wouldnt do it yet.You can clog up the oil passages and thus lock up the motor.
Post a Followup
: Re: Re: Farmall H [Knockin] Can I ?
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
