3 timing notches on crank pulley which one to use???????
Posted by Chad Penny on February 26, 2003 at 08:23:38 from (152.72.252.244):
Putting this farmall H back together and I want to adjust the valves and I need to install the distributor yikes!!!!!
Which notch on the crank pulley is the correct one to use? There is 1 by itself and then there is two other ones about 3/8" apart and half way around the pulley from the other. I thought the singal one was the top dead center mark but I looked in the spark plug hole and I could not see the piston so I rolled it around till I seen the piston and both valves were closed. It is close to the two marks. Which one of the two marks do I use? Please help
Chad
Post A Followup
: Re: 3 timing notches on crank pulley which one to use???????
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
