H hydraulic pump - run continuously?
Posted by Brent on March 03, 2003 at 17:53:13 from (216.248.74.131):
A fellow in an earlier post had "wired" his lift-all lever in the lift position and used it to run a "live" hydraulic feed to a spool valve set-up. I had thought of using my belly pump like this to run a "live" system but wasn't sure if it would damage it leaving it running constantly, even when the spool valve it fed was closed.
Would this cause damage, or would the spool valve just flow oil back to the resevoir when pressure wasn't needed? Even if it did, would running the pump continuously cause damage?
Post A Followup
: Re: H hydraulic pump - run continuously?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
