Farmall Tractors Discussion Board
Re: over-running coupler
Posted by ltf in nc on September 09, 1999 at 13:34:36 from (206.228.213.213):
In Reply to: over-running coupler posted by paul on September 09, 1999 at 09:53:55:
I assume that your drawbar must be straight as opposed to a vertical offset type. The offset version can just be turned over. I would make a device like a receiver hitch for a truck and mount it on the drawbar. Then I would make an insert of the height I desired. It is convenient also to make an adapter to mount a ball to the "receiver" hitch. I even have one for a pintle hook. This will let you move a trailer, etc. around without have to bolt everything together. Should you decide to get an overrunning clutch, I bought one that readily attaches and dismounts very reasonably, $41.90 delivered from 1-800 345 -0169. The 1 3/8" x1 3/8" diameter ones are $2 more. An overrunning clutch is a must on these older tractors to avoid stressing the drive line as well as it is much safer.
Post a Followup
: Re: Re: over-running coupler
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
