Re: Carb Adjustment Farmall 400
Posted by Bob M on March 16, 2003 at 07:21:43 from (66.66.123.133):
In Reply to: Carb Adjustment Farmall 400 posted by Scott(TN) on March 16, 2003 at 06:22:11:
Scott - A couple easy things to try first: Remove the air inlet hose at the carb. Make sure the choke opens all the way when the knob is pushed in - adjust the cable if it does not. Now run the motor with the air hose off. If it runs better, the air cleaner is plugged and should be cleaned. If that doesn't help, run the bottom carb adjusting screw (high speed adjustment) in all the way. Then back it out 1 turn and try the motor again. If this helps, adjust this screw in or out as required for best running at full throttle. The upper screw is the idle mixture adjustment. If turning it in/out has no effect on idle speed/smoothness, it means the carb idle circuit is plugged. Only fix is to remove, disassemble and thoroughly clean the carburetor. Finally another possibility is the cam drive gear key has sheared. This causes valve timing to drift resulting in loss of power and black exhaust. It may cause the spark timing to jump around as you observed. It may also be accompanied by a knocking sound from the front end of the motor when idling. And if you remove the hydraulic pump you may sometimes (but not always) find the cam gear inside can be moved a bit under finger pressure. The only solution is to remove the tractor front end, timing cover and cam gear, then installing a new key. Not a difficult job but requires removing large/heavy parts to get to it. (Note: This seems to be a common problem with 4 cylinder Farmalls with live hydraulics - it's happened to my Super M, also to a buddy's SMTA and 400.) Good luck!!
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
