Re: model H ring gear
Posted by Theman on March 19, 2003 at 10:10:04 from (12.19.86.5):
In Reply to: model H ring gear posted by jeff on March 18, 2003 at 17:22:19:
Jeff, installation of the ring gear is pretty straightforward. To get a new set of teeth on mine I carefully removed the gear and turned it over. It works well. The procedure once you have removed the flywheel from the engine: Clamp the transmission input shaft in the vise (6" wide jaws or larger) with the stub that goes in the pilot bearing pointing straight up and extending above the jaws about 4". Gently set the flywheel with pilot bearing still in it on the shaft so you can turn the flywheel. Make sure the clutch side of the flywheel is down, you don't want the weight of the flywheel to press the pilot bearing out and allow the flywheel to fall. With the torch pointing straight at the ring gear, turn the flywheel slowly and gently bring the ring gear up to temperature. DON'T get any of the ring gear red hot. Stop when you start to see a color change then tap it loose with a brass drift working your way around the gear. Once you have the gear off, take it in the house and put it in the oven set to 500°F. Go back to the vise and remove the flywheel from the input shaft and set it face (clutch side) down on the bench. Be careful, it may still be warm. Wire brush and clean up the flywheel where the ring will go back on. After about 15 minutes, retrieve the ring gear - still wearing heavy leather gloves - and drop it in place with the new side of the teeth toward the clutch side of the flywheel. When placing the ring gear over the flywheel its a good idea to hold it down against the flange on the flywheel while it cools. This will only take a few seconds. The ring gear I put on my H came away from the flange a little bit as it cooled and had to be tapped down while it was still warm.
Home
| Forums
Today's Featured Article -
Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
