Re: Re: 'C' BRAKES
Posted by ferg farms on March 20, 2003 at 18:14:06 from (24.197.0.6):
In Reply to: Re: 'C' BRAKES posted by Randy in NE on March 20, 2003 at 07:27:30:
your are on the right track. slide the drum off,you may not need a puller.the seal is behind the drum.try running a sheetmetal into the seal and pull it like pulling a nail.you may have to tear the seal into pieces to get it out.Do NOT REMOVE THE COVER PLATE THAT HOLDS THE SEAL UNLESS YOU ARE REPLACING THE BEARING. THIS COVER IS SHIMMED TO SET THE TOOTH PATTERN FOR THE RING GEAR.
Post A Followup
: Re: Re: Re: 'C' BRAKES
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
