Farmall Tractors Discussion Board
HELP!! My tractor won't run- carb flooding
Posted by Todd K on September 10, 1999 at 08:05:57 from (12.2.115.11):
HELP
I have an 1964 Oliver 550 gas with a Marvel-Schebler TSX-811 (64F) updraft Carburetor . I recently cleaned out the carburetor when the lead additive jelled and plugged the carbureator after 5 months of nonuse.
When I set the “High Speed Load Adjustment” screw gas siphons from the gas tank and through the main nozzle into the venturi and out the throat until I shut off the fuel valve at the tank.
The float seems to be Ok it floats and there are no sloshing sounds as if it is leaking and gas is getting inside of it.
When I test on the bench the needle and seat seem to seal when I hold the float up and open when I let the float go.
The float is set at the manual specification of ¼” down form the gasket surface.
I have a carburetor rebuild kit and I hope this solves the problem when I rebuild the carburetor ( I used all the old gaskets when I cleaned out the carb)
Am I missing something? Is there anything I overlooked ? Is there some trick to rebuilding a Marvel-Schebler updraft carburetor?
I am desperate and frustrated as the tractor always ran great and now I do not know what to do the get it running again.
Can anyone Please help me out there????
Thank you
Post a Followup
: Re: HELP!! My tractor won't run- carb flooding
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
