Farmall Tractors Discussion Board
Water in Oil After Overhaul
Posted by Bill(Tx) on September 12, 1999 at 18:48:55 from (151.164.37.171):
Checked the oil for ring dust after 3 hours on the engine and found water also, probably 6 ounces. Then checked head bolts for 70 ft/lbs. All execept one were pretty close in the spec range. The front right bolt (nearest to generator) spun around and discovered the stud treads are stripped. I tried another stud from a spare block with the same result. Guess I'll have to try the heli coil. Any tips on using the heli coil repair? Would the stripped stud be contributing to the leak? Can I reuse the head gasket, and would damage be minimal with 3 hours on the engine? Grrr.
Post a Followup
: Re: Water in Oil After Overhaul
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
