Re: Farmall F-20 timing
Posted by Bill Smith on April 24, 2003 at 12:30:50 from (63.147.130.62):
In Reply to: Farmall F-20 timing posted by Andrew on April 21, 2003 at 14:40:31:
The timing marks are located in the hole of clutch housing when at TDC. I have never been able to see those marks. I always find the TDC the old fashioned way. Find the compression stroke of #1 cylinder and then run the piston right up to the top of stroke. Much easier to do with all the plugs out. I just take mag off at this point. Put a wire or nail in (I'm not sure which one) one of the oil ports on the front of mag. You can in-activate the impulse this way. Put the advance all the way down (in the run position). Rotate mag until the points just open on the number one plug. In this postion is how the mag needs to be bolted to tractor. As mentioned by others, you may have to unbolt the coupler thingy mergiger and rotate a hole or two to get everything lined up. After you get mag bolted on, remove the wire or nail from impulse, finish putting tractor together, adjust the spark advance on mag to the start position, and you should be able to crank it up. Ounce it is started, lower the advance to run position. A gasoline engine that is timed correctly should fire slightly before TDC. Since you have a mag with an advance, this would be in the run position.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
