Re: FARMALL C HYDRAULICS
Posted by Haas on May 07, 2003 at 03:39:49 from (166.72.245.23):
In Reply to: FARMALL C HYDRAULICS posted by TIM DALY on May 06, 2003 at 19:35:52:
You can't tap into those for connect of a remote cylinder to have both the remote and the touch control operate normally. The system only generates pressure when the touch control levers are moved, or are not properly adjusted and are at the end of their travel, causing the system to generate pressure. You can also lock the rockshaft arms so they can't move and then move the touch control levers and that will cause pressure to be generated. If you want to do it that way, what you do is tap into the pressure connection on the hydraulic manifold. I think it's the one to the rear. Go from that to your new remote valve and run the return from the remote valve either to the fill line of the touch control reservoir or to the drain. Then lock the rockshafts so they can't move and move the touch control levers to a different position to cause flow to go through the remote valve. If you do it this way, you won't be able to use the touch control rockshafts. You can buy a block with taps for a remote from Saginaw County Tractor. The block goes between the hydraulic manifold (under the piece that has the pipe plugs in it) and the touch control unit. If you do it that way, you can still use the touch control rockshafts when you have the remote connectec.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
