Adding dual remotes to H hydralics
Posted by Kelly C --- the hydralics idot. on May 17, 2003 at 19:29:39 from (63.171.43.140):
Ok guys. For some reason I cant visualize how this is done or if it can be.
I would like to add a remote system to my H.
This would be a line from the lift all. to the remote. then a line back to the bottom of the lift all. ( the lift all would pump all the time.
Same as Steven@ND has.
Then I would run 2 lines to my 3pt hitch (when I get it)
To give up and down pressure. This much I can visualize.
The problem is my loader. it is single action. IE it needs to drain back into the hydralic system using its own wheight.
Can this be done?
If not maybe there is some kind of splitter valve that I could run the 2 single action. I dont know.
Post A Followup
: Re: Adding dual remotes to H hydralics
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
