Re: Now what?
Posted by Loren on May 21, 2003 at 09:52:04 from (64.65.174.118):
In Reply to: Now what? posted by Jason (SC) on May 20, 2003 at 21:23:28:
We use Iron Etch, made by Martin Senyour paints and sold at NAPA. It's a phosphoric acid solution used as a metal prep. for painting, but it works wonders on stuck pistons. I broke loose two pistons on an M that sat for many years without a cap on the exhaust. I also used it on two pistons on my 10-20 and my A. Works every time. I'm going to use it on the stuck W9 that I brought home last month also. When I'm ready to work on the motor, I don't have the patience to wait weeks or months for the pistons to soak. Just pour about 1/2" of the solution (don't dilute it) on top of the piston and let it sit overnight, then the next day use a block of wood to drive the piston down. You should probably take the rod bearing caps off the other pistons and use a rag to keep the rods clear of the crank, so you're only trying to move one piston at a time. If the rod bearings are disconnected, you can try using a long piece of wood to try driving the pistons upward. Some of them may not be stuck, so you can get them out of your way. You may want to have someone help by turning the crank or flywheel while you're driving the piston down. I prefer to remove the starter and use a pry bar against the ring gear teeth vs. turning a back wheel, so you're not risking messing up the clutch. If you use Iron Etch, make sure to rinse everything off afterward, as it is mildly corrosive. It will leave a slightly rough finish on the cylinder where it sat overnight, but it will hone out. Email me with any questions. I brought an M back from a similar situation three years ago, and it's now the best running tractor we have, so there is hope for it.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
