Trouble starting Farmall tractor
Posted by Gary Morstadt on May 25, 2003 at 09:23:03 from (152.163.190.1):
1952 Farmall M - owned two years without problem. Started strong everytime until this time. Electic start, 12 volt system. Turned key stepped on the starter lever and got sizzle sound. Removed and cleaned all wiring (found wire from ignition to starter loose), found battery discharged. Installed another battery and it cranked, seemed to start, but then when I let off of the starter level after hearing the cylinders fire, it stops as if the coil wire was disconnected. Checked that and it is fine. One other thing is, not sure if it is called a starter or generator, the throw out bearing seems to spin and wine after I let off of the starter lever. It must be engaging the flywheel because I can hear the motor turn over and start to fire the cylinders. I took it apart and found nothing wrong except slightly worn teeth. Flywheel looks fine as well. What could be the problem and what else could I check? Also, on a lighter note, the oil filter housing leaks oil through the bolt on top of its housing. I read in a manual that there should be a gasket to go along with the filter, but none are included with the filter when I bought it. Thanks, Gary Morstadt
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
