Re: hydraulic lift on super A
Posted by CNKS on May 28, 2003 at 19:09:13 from (207.178.96.214):
In Reply to: hydraulic lift on super A posted by Dave Feldman on May 28, 2003 at 17:58:53:
Could be several things. First make sure you have enough oil. Should be slightly below oil fill with levers in the rear position. Use Hytran hydraulic oil. Your screen could be plugged -- remove three small bolts below the fill hole and it comes out, there may be a rod in the way. The hydraulic pump not working is not very likely, unless it has been run without oil, or if the oil was changed and it did not prime. There could be air in the system, this is usually fixed by cycling the levers several times, usually done after an oil change. Or, your resevoir, whch has several channels, o-rings etc, might need to be removed and cleaned -- kit from IH is about $90.
Post A Followup
: Re: Re: hydraulic lift on super A
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
