Re: 300U carb
Posted by Bob M on May 30, 2003 at 10:38:32 from (165.170.128.65):
In Reply to: 300U carb posted by D.Sellers on May 30, 2003 at 09:51:35:
I just did the carb on a friend's 400 - had the same symptoms you describe. Problem was bits of junk - rust flakes or bits of deteriorated gasket? - loose in the bottom of the bowl. Apparently one would occasionally get sucked into the high speed jet and partially clog it. It then required working the choke to keep the motor running. A thorough cleaning of the carb insides solved the problem. When you open your carb look for loose stuff in the bottom of the float bowl. Clean out anything you find. Clean thoroughly (blow out) the high speed jet - that's the brass orifice the high speed adjusting needle "point" fits into. Also check the condition of the filter screen behind the fuel inlet fitting on the air horn. On my buddy's the filter screen had split open. This let any dirt, rust etc. that came down the gas line right into the float bowl. (Was able to fix the screen by reshaping it and soldering the seam….) Before you reinstall the carb, check the inside of the gas tank for rust and clean out if necessary. Clean also the sediment bulb and strainer screen. Then just before you reconnect the gas line, flush a cup or two of clean gas thru the line to purge anything that might be loose there. Good luck! That carb is relatively simple and is easy to clean/rebuild.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
