Re: Hydraulic help - basic questions
Posted by dick on June 07, 2003 at 08:49:05 from (67.31.149.250):
In Reply to: Hydraulic help - basic questions posted by Doug Stockman on June 05, 2003 at 02:53:41:
Based upon your description of what you have, I think what's below should be accurate - however, I don't have a 460U so I'm doing some guessing. Hopefully this will be at least somewhat useful to you: 1, teeing into the supply line before the IH valve: wouldn't work on a hundred-series tractor (300, 400, etc.), but might on yours??? The IH hydraulic system on the hundred series has a third (internal) line for control of loading/unloading the hydraulic pump, and your system probably has this also since it's nearly the same vintage tractor. If this is what you have, the IH valve with its handle tied back all the time is necessary to load the hydraulic pump continuously, even though it isn't producing high pressure unless your add-on spool valve is activated. If this matches your hydraulic system's design and you tee into the supply line hoping to use the IH valve exclusively for the hitch, you won't get high pressure hydraulic fluid to your loader unless you run your hitch up or down at the same time as your loader. 2, adding another add-on control valve: should work. What you have now with the add-on valve portion of your system seems to be an open-center setup which should allow you to add another valve in series (not parallel). 3, dual-acting: this SHOULD be controlled by the IH valve alone, and should work. A test you should try is to remove the hoses going to the add-on spool valve, plug the open ports on the IH valve, switch over to the double-acting setting, and see whether your hitch starts working the way you want it to work. Since you'll be using some parts of the system that haven't been used for a while, start out at low RPMs, and be on the lookout for problems. If this works, you should be in pretty good shape to implement #2 as far as the hitch is concerned. For the loader, you didn't indicate whether the add-on spool valve had plugged-off return ports; assuming it does, a hose between the plugged-off port on a cylinder and the plugged-off port on the corresponding valve should give you dual-action on your loader. You're probably still going to need to keep the handle on the IH control valve wired back to have this all work (see #1). I hope this is both clear and correct. Email me if you have questions, etc., and please be careful.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
