Re: Voltage Regulator Problem??
Posted by Bob M on June 10, 2003 at 18:55:45 from (24.169.118.255):
In Reply to: Voltage Regulator Problem?? posted by Larry in CO on June 10, 2003 at 17:08:51:
Thanks for your kind words Larry! Unless your battery is fully charged, the ammeter will behave exactly as you describe. If it's partially discharged it may take several hours of running the motor at full RPM before the battery is brought up to where the regulator will cut back the charge rate. If you have an accurate voltmeter, stick it across the battery and note the reading at full RPM. If the voltage is 7.2 or less, everything is fine. Only if you get a reading above about 7.4 or 7.5 volts should you consider replacing the regulator. Don't have a voltmeter? Stick a charger on the battery and let it charge for 24 hours. Then start the motor and run at full RPM. The ammeter should show a high charge rate (12 - 15 amps) immediately after starting, then fall back to 5 amps or less as the battery reaches full charge (usually after several minutes). Note: All the above presumes the battery is in good shape. A battery that's failing may charge at a high rate all the time. Hope this helps....
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
