Re: Farmall M Cuts Out....Help?!
Posted by Steve - IN on June 30, 2003 at 21:56:00 from (12.223.205.149):
In Reply to: Farmall M Cuts Out....Help?! posted by M Owner on June 30, 2003 at 21:17:51:
M Owner, Here are a couple of ideas... When it cuts out at high speed or under load, see if it clears up a bit when you pull out the choke a bit. If it does, there's some fuel flow problem starving it when it needs more fuel at higher RPM. If not, I'd guess ignition. Did you add a new condensor? Probably not the problem, but maybe. More likely you could have a distributor cap that's arcing from one tower to another (sometimes you can see carbon traces on the inside of the cap that give away this problem), or an old, worn distributor shaft that sprays sparks about anywhere when it starts turning fast. It's also possible there's a problem with one of the new plug wires, assume you're using copper stranded wire and not carbon core wire? Those are the first things that come to mind. Try the above tests. Try wobbling the distributor shaft (should be fairly tight) and try subbing out old plug wires for new, and post back if that still doesn't isolate the problem. Good luck with the old guy...
Home
| Forums
Today's Featured Article -
Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
