Farmall H oil leak........
Posted by IH Man on July 01, 2003 at 11:28:40 from (165.247.69.35):
I am experiencing an oil leak coming from above the pan cover at the rear of the hydraulic unit.I removed the pan cover and noticed that someone has used silicone around the piece that bolts to the transmission where the shaft extends out that drives the Hydraulic pump. Is there a seal and a gasket that can be replaced? The fluid leaking is not hydraulic its transmission/differential oil.
I may just remove the hydraulic pump being I don't use it. Oil leak is pretty steady while driving the tractor. Any feedback regarding fixing this leak appreciated.
Post A Followup
: Re: Farmall H oil leak........
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
