Re: Another A farmall charging problem
Posted by Bob M on July 02, 2003 at 05:33:16 from (165.170.128.65):
In Reply to: Another A farmall charging problem posted by Terry on July 01, 2003 at 21:32:10:
Terry - Sounds like a problem in the generator field control circuit - probably a poorly grounded ammeter box or bad light switch. Try this: Run a temporary jumper wire from the grounded battery terminal to some clean metal on the ammeter box cover, then run the motor. If the ammeter now shows 10 amps or so, you need to clean up between the box cover and the tractor frame to give it a good ground. (Or you can run a permanent ground wire to the box cover). If the above doesn't work, try temporarily grounding the generator field terminal at the light switch. If the ammeter now shows a charge it says the problem is with the light switch (bad switch or field resistor). If THAT doesn't work, problem's gotta be in the wiring (broken wire) between the light switch and the generator. Also note: When using your voltmeter to test system operation, stick the probes directly on the battery terminals. If the generator is charging the voltmeter should show 7.0 volts or a bit higher at the battery. Also as you observed, some DVM's give erroneous readings on generator systems on account of electrical system "noise" caused by the generator. Your analog meter will give you the most accurate readings for this type of work - presuming it's in calibration of course… Hope this helps!
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
