Re: Oil Pressure- Super A
Posted by Randy in NE on July 09, 2003 at 09:22:32 from (216.58.237.20):
In Reply to: Oil Pressure- Super A posted by PGNS on July 09, 2003 at 08:46:51:
When the oil is cold you should have at least 1/2 to 2/3 deflection of the needle. When it warms up and is idling it will be lower. When my C (same engine) is warmed up and idling it goes to just a little less than half way which on my guage is about 25-30 lbs. I have about 70 lbs with cold oil pressure at max rpms. Replacing the oil pan gasket will have absolutely no effect on the oil pressure. As far as the metal plate that is most likely the plate on the bottom side of the oil pickup assembly for the oil pump. It floats in your oil so that the pump is not sucking the gunk off the bottom of the oil pan. This allows for fluctuations in the oil level due to oil draining back from the top of the motor, side hill operation, and for those that do not always check the oil level and the possibility of lower than recommended oil level. Not much to removing the oil pan and replacing the gasket. Good opportunity to clean all of the dirt and metal files from the bottom of the pan. The gasket is readily available from you local Case/IH dealer for just a couple of dollars.
Post A Followup
: Re: Re: Oil Pressure- Super A
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
