H PTO Drive Removal
Posted by John Kerber on July 31, 2003 at 03:54:08 from (24.197.103.231):
I was bushhogging with an H without a shear pin, hit a rock and lost 1- 4th gears. I removed the tranny cover plate and the top 2 set of gears and at least 1 gear on the lowest shaft is stripped.
My question is how do I remove that lowest shaft? I found the retainer ring on the back end of the shaft where the actulal PTO shaft mates, but on the front of that shaft is a bearing with three bolts. I remove the bolts, but nothing moves. The front of the shaft has a large slot where a short coupling can be removed. Do I try and drive that entire lower shaft forward (toward the front of the engine)?
I read in an IT manual to "remove the nut" on the front of the shaft, but the only "nut" I have found up there is the one working on it.
Thanks in advance for the help. JK
Post A Followup
: Re: H PTO Drive Removal
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
