Re: Farmall 140 Hydaulics
Posted by Gary-Miss on August 04, 2003 at 17:22:52 from (64.12.97.13):
In Reply to: Farmall 140 Hydaulics posted by Scott on August 04, 2003 at 16:40:50:
There is an O ring on each of the touch control rods. They are recessed inside the housing. You will need to make an extractor out of a welding rod or such. Putting them back in is no problem. Drain the touch control. You probably need to was the screen (held in by four bolts on the left side) anyway and this is a good time. Disconnect the hydraulic lines on the right side. You will need a NEW gasket for that. Disconnect thecontrol levers. remove the four mounting bolts. Unfasten the control valves from the left arms, remove the lift arms and pull the control valves out. Thjey aren't fastened to anything inside the unit. You will see the"O" rings up inside. You can buy a pair of universal rack and pinion boots to replace the boots from an auto parts store. When you get through, refill with oil, have a blow gun and a rag ready to shoot just a little air into the filler hole. You may not have to if you don't remove the lines from the pump itself. Good luck
Post A Followup
: Re: Re: Farmall 140 Hydaulics
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
