Farmall Tractors Discussion Board
Re: Trailering a Farmall H
Posted by Phil Auten on September 23, 1999 at 06:01:41 from (206.175.72.226):
In Reply to: Trailering a Farmall H posted by Steve Sayers on September 22, 1999 at 13:34:35:
Steve,
I trailered my M home from where I bought it on my 6000# tandem with brakes pulled by a F-150 with the 4.9L six cyl/5-speed manual trans. The trip was about 100 miles with terrain varying from hilly to flat. I used premium gas to avoid knocking and only had to downshift out of OD a couple of times to maintain a minimum speed of 50 mph. The M weighs almost 5000 lbs. and I wouldn't trailer it without brakes. The other thing to look at is overall width of the H. I had to reverse one rear wheel on the M so it would fit the trailer. The H is only slightly smaller than the M so the trailer should be as close to 8' wide as possible unless you can turn the wheels so the dished side is in. If your truck is an automatic overdrive, i suggest you lock out the OD so you don't overheat the trans. Be careful and lookout for idiot drivers, they're your biggest danger.
Phil
Post a Followup
: Re: Re: Trailering a Farmall H
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
