Re: will not idle
Posted by Tim Kincaid on August 09, 2003 at 08:17:22 from (216.175.23.46):
In Reply to: will not idle posted by d.naylor on August 08, 2003 at 19:51:44:
Take the linkage loose from the the carb and see if the throttle shaft has free movement all the way thru its range. It could probably use some lubrication if it hasn't been off for awhile or the little seal has become damaged somehow.
Good Luck Tim K.
ps. Butterfly could be hanging up also.
Post A Followup
: Re: Re: will not idle
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
