Re: F-14 fuel pump rebuild
Posted by Karl O on August 13, 2003 at 09:05:40 from (198.76.182.85):
In Reply to: F-14 fuel pump rebuild posted by RLS ia on August 11, 2003 at 18:56:27:
There are at least three different styles of check valve for the F-12/F-14 fuel pump. Probably the easiest thing to do is to blow through the pump after you have it done (and sediment bowl back in place). You should be able to blow thru the pump if you put your mouth (or pressure nozzle) on the inlet port. You should NOT be able to blow thru the pump if you put air on the pump outlet.
Or just do some thinkin'. The fuel flow must push the check valve off its seat against spring resistance. So the spring goes on the 'low pressure' side of the system.
Post A Followup
: Re: Re: F-14 fuel pump rebuild
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
