Re: Valve clearance when cold?
Posted by Bill Smith on August 22, 2003 at 16:10:51 from (63.147.130.56):
In Reply to: Valve clearance when cold? posted by dvtw on August 22, 2003 at 08:52:46:
I ussually adjust valve clearance to what is specified for hot even though the engine is cold. Then I put the valve cover back on and run untill engine reaches normal operating temperatures. Then I simply remove the valve cover and re-do the valve clearance procedure. This way the valve clearance can be adjusted while the valves are hot and you will be close to start out with. Ussually you will only have to adjust slightly, but I still re-adjust just because the specification is for hot. Then you can put the valve cover, hood, and what not back on.
Post A Followup
: Re: Re: Valve clearance when cold?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
