Re: Need Help with W6!!!
Posted by Haas on August 25, 2003 at 05:51:28 from (12.65.44.102):
In Reply to: Need Help with W6!!! posted by Dave Wiley on August 24, 2003 at 19:54:00:
I all is set up correctly, connecting the battery either positive or negative ground will work. However, I expect the W-6 was originally positive ground. You don't say if you have battery ignition or a magneto or if you have original 6 volt generator or has been converted to a 12 volt alternator. However, it sounds as though your generator is not charging the battery and your ignition is running the battery down after a time. Things to check. Does your amp gage show charge?? If you have a generator, is it correctly polarized. If you have a generator and it does not show charge on the ammeter, then you can check the generator by grounding the field terminal (carefull not to ground anything else) With the field terminal of the generator grounded you should get max charge rate of around 10 to 15 amps if you have the original generator. If you don't, likely the regulator or the cut out relay is bad. Hope this helps.
Post A Followup
: Re: Re: Need Help with W6!!!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
