Re: Re: Re: ? for randy hall + others about compre
Posted by Steve - IN on September 10, 2003 at 18:21:06 from (12.222.30.13):
In Reply to: Re: Re: ? for randy hall + others about compresion posted by Guy Fay on September 10, 2003 at 15:22:42:
Guy,
If it's a distillate engine, it has an even lower compression ratio than the gas version, so it should create less of an explosion -- less heat -- than a comparable gas engine assuming both use the same pump gas.
Also, if I remember correctly from chemistry classes and flight school -- the heat ducting shields help prevent the heavier kerosene molecule (with 10 to 12 carbon atoms) from falling out of suspension; as it's heavier than the octane gas molecule with 8 carbon atoms. It was all academic in chemistry, but in flight school the benefits carb heat and the inverse of augering in, or "bought the farm" were heavily emphasized. You know.. the old pilots and the bold pilots, but rarely do you find an old, bold pilot.
Post A Followup
: Re: Re: Re: Re: ? for randy hall + others about compre
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
