Re: Farmall A Timing Problems
Posted by Bob on September 12, 2003 at 08:48:46 from (66.163.134.177):
In Reply to: Farmall A Timing Problems posted by Richard Fazio on September 12, 2003 at 07:25:36:
Somewhere in that 20 - 30 degree range would be CORRECT RUNNING TIMING. (I don't know offhand what the exact lag degree spec of your impulse would be.) At cranking speed, the IMPULSE COUPLING in the mag catches, winds up a spring for 20 or so degrees of crankshaft rotation, and then "trips", giving you a HOT spark at about 0 degrees.
This does 2 things... the quick snap of the spring gives a hot spark from the mag to aid in starting, and the winding up of the spring retards the spark timing for starting. This "static" setting at about 0 degrees is important because if the engine were ever to be hand cranked, you do not want a spark before 0 degrees (TDC), as a "kickback" will occur, likely to injure the person cranking! When these tractors were made, the manual usually referred to "static" timing", as timing lights were not commonly available in farm settings, and the timing could easily be set by slowly rotating the engine with the spark disabled, and the point at which the impulse coupling "snapped" could be referenced against a timing mark. As the engine "catches", and speeds up, centrifugal force acts on weights in the impulse coupling, and swings them to a position where they do not "catch", disabling the snap action, and the timing advances all at once to the running timing. In that way, the timing on these "mag" engines differs from engines with a distributor. With a distributor, the spark advance occurs from idle up towards governed speed at a rate determined by the "ADVANCE CURVE", which is set up by the manufacturer's choice of weights and springs in the advanve mechanism. To sum this up... If you set the static timing to the manufacturer's spec for static timing (X number of degrees, or a mark labeled "spark") at which the impulse should trip as the engine is SLOWLY turned over, the running timing WILL BE CORRECT, ASSUMING THE CORRECT IMPULSE COUPLING IS PRESENT ON THE MAG, AND IS FUNCTIONING PROPERLY.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
