IH 504 problems
Posted by Tom on September 23, 2003 at 16:25:58 from (65.166.178.122):
I have 503 industrial with a front end loader and back hoe I have about 300 hours on a engine
rebuilt. I has set for a couple of years. I decided to sell it this year but while getting it
running I had a lot of blue smoke and a knocking in the engine.
I pulled the valve cover and I found two bent push rods, and one missing push rods.
I replaced them but could not find the missing push rod in the upper end. I also poured some
Rislow over the valves and re-adjusted the valve lash, and it was smoking a lot less.
but still smoking.
I pulled the Oil pan, and found it had spun a rod bearing to little pieces and I have
another rod that's a little sloppy on the crank. It also acts like it has stuck rings.
Right now I guess I would be looking at a used crankshaft, lower end rebuilt kit at least one
connecting rod. Plus some seals on the rear axles
Would I be better off?
1. fixing it
2. calling the junk yard and having it hauled off.
3. parting it out and making every one who need 504 parts a really good deal
4. Filling the wash out with the tractor instead of using the tractor to fill the washout.
At the moment I amd strongly in favor of 4.
Post A Followup
: Re: IH 504 problems
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
