Farmall Tractors Discussion Board
Re: Re: SMTA HYDRAULICS
Posted by Stan(VA). on September 28, 1999 at 10:21:16 from (207.172.109.218):
In Reply to: Re: SMTA HYDRAULICS posted by Ronnie on September 28, 1999 at 07:49:29:
An alternative is to go buy an aftermarket 2way open center valve, mount it to the side of the battery box below your seat so the handle is convienient to your hand. Take any one of the 3 ports you mentioned to the valve, with the return going to a tee on the filler neck. Then run the two work ports on the new valve to your cylinder(s). To operate it just tie the short control rod in the full on position (so it is supplying hyd feed all the time.
While you're going to the trouble get a two spool valve instead of single and you will have an extra valve for a set of remotes.
Stan(VA).
Post a Followup
: Re: Re: Re: SMTA HYDRAULICS
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
